Replacing leaf springs with 2013 leaf springs
HtxChapter
Take some time and pull the springs apart and lube them with some good synthetic waterproof lube at the center pin area. there are some aluminium shims between each spring and look for any area that has evidence of rubbing and lube it too. I did this when I lowered my truck and no sqeaks 4 years later
RT
NAPA sells a product called Sil-Glyde. Very good lube an water/moisture won't bother it. I'd use it, and sparingly to keep road grime/dust to a minimum.
    Dom Colussi
    Dom Colussi
  • Who's Online   2 Members, 0 Anonymous, 483 Guests (See full list)
