Alright so this is my first time using a forum so hopefully this helps.
I have a 2007 Chevy Silverado 1500 Classic 4.8l LS crew cab with factory 20" wheels; about a year ago I installed a bullydog tuner and not to long after that I started to noticed my brake pedal starting to pulse pretty bad fairly often and since my truck has 125k miles i went ahead and replaced the pads and turned the rotors thinking they were probably getting pretty worn. unfortunately that didnt fixed my problem and realized it was actually an abs problem due to the fact my abs light started to come on along with the abs pump (I realized later that the pump was causing my pedal pulsing) and slowly as the weeks went by it began to get worse and more frequent. It got so bad to the point were everytime you go to stop the pedal sputters and the speedometer goes crazy and my abs and brake lights come on the dash along with "service brake system". It started to drive me crazy so since I work in a shop i started to ask around and everyone kept suggesting to watch it on a scan tool and see which wheel was messing up so i did and the rear wheel speed singal kept dropping out so i put in a speed sensor and it didnt fix it so i returned the sensor. Well now currently... the abs pump activates all the time (even without touching the brake pedal while driving), my speedometer goes in and out and now my transmission is shifting crazy. for example if you're driving down a road crusing between 40 and 50 mph the transmission will randomly shift from 4th to 1st and when you try to accelerate you dont have any gear to grab onto except 1st till it decides to shift to the proper gear (very annoying when you're in traffic and having to slow down so you're not cruising at 6k rpms). Ive replaced the abs control moduel, rewired the wires from the abs control module to the pcm and from pcm to the rear wheel speed sensor, replaced the rear wheel speed sensor, and now the pcm. my truck is pretty basic and doesnt have any kind of traction control and has two abs sensors on the front wheels and one abs sensor (vss) mounted ontop of the transmission. nothing has worked and ive had 3 different crazy good master techs who are also master electrical diag techs and they couldn't figure it out. my truck has 145k miles on it now and doesnt leak a drop of oil ANYWHERE and runs so darn good... i dont want to get rid of it just because of this.
Thanks in advance!!
Do you have a drums or disk rear?
Sent from my Z981 using Tapatalk
What codes is it throwing?
it has drums. and i believe if im remembering correctly it throws a c0055 for loss of rear wheel speed signal
I am all out of ideas with this thing. Ive replaced the abs control module, pcm, rear wheel speed sensor, cleaned the front wheel speed sensors like the tsb says to do, ive replaced all related wiring and its still messed up....
  • 3 years later...
On 7/31/2020 at 5:07 PM, Cameron Jenkins said:
I got a truck that is doing the same thing and I was wondering if you ever figure out what was causing the problems.
Hey man, Yea i figured it out.  been a while haha  Ive gotten rid of the truck since then.  turns out the transmission needed to be rebuilt because a C clip came out on the output shaft and was allowing the output shaft to slide in and out as I accelerated.  Had to tear the transmission all the way down to access this part so ended up just rebuilding the whole thing.
You can confirm this is your issue but removing your drive shaft and grabbing the output shaft and if it can be pulled out and shoved back in then thats your problem.  The output shaft should be firm in place.  basically whats happening is the output shaft has a reluctor wheel on it that the WSS reads and when you let off the pedal, the pressure in the transmission and is released and the output shaft moves backwards, causing the reluctor wheel to move out of view of the WSS which in turn makes the ABS Module think the back tires have gone to 0 MPH and thinks it sliding.
Best of luck to you.  Hopefully yours isnt this issue but if it is then be prepared for a transmission.
    • Atlas,   Then following your logic we can't believe any story that the MSM produces? I mean it's documented they heavily donate to Democrat candidates. Vote Democrat in high percentages. Many MSM talents are married to Democrat politicians, Gov. employees. That goes for on-air and off, personalities and reporters. So they would all be biased and nothing they produce is to be believed in your mind?   Again the article simply was about ways AI can be used for pricing products. Nothing discounted current situations as a factor.    Again keep looking through your left/right lenses. I don't live my life that way.   And as a heads up this thread will be cleaned up again as much of this is off topic and is receiving
    • Yes, and only a couple years before delivery. 🙄
    • So you're saying toss the baby out with the bathwater? @txab posted article was her take on how AI can be used to manipulate pricing as it already does and has been rebuked by the judiciasry in housing. How AI can be and is used to maximize refinery or even Amazon operations all of which are true but because she is who she is; that makes what she says about what is true, false? Is that something akin to Pre-justice aka prejudice?    Look, I'm first in line to approach all information with caution just because we live in a world where people like to lie about someone or something with such a straight face and in such volume that it makes digging to the truth wearisome. Meaning I understand the skepticisms but if I were to toss out everything a person is for a view they hold then my pool of people to draw wisdom from would be non-existent and I'd be forced to reinvent the wheel daily. Not practical.    "Be innocent as a dove but as cautious as a serpent."    Test each word. Every good lie is part truth or no one would believe it. Find the truth in it and reject what isn't.    On this one, AI is being used to do what has been done by hand for hundreds of years already but at such speed, the point of a computer, that it is more easily monetized. This one wasn't that hard a lift.    I wrote a few formulas in a Lotus 123 program decades ago, a series of linked Macros actually, that allowed a daily inventory to be turned into a running P&L and production plan. Something that took three departments a week to assemble now took the time it takes to input the 'daily changes' in inventory. Later that was ungraded to the more powerful Excel program an and integrated with bar code scanning, inventory to supply was done once per shift. It had a huge impact on production scheduling, Seamless interruption flexibility, inventory error reduction, raw materials cost effective utilization and scrap reduction. Huge improvement in the bottom line. I spent months on that and AI could have done it in minutes. So yes, it not only can be used, they would be foolish to not try. The legality, ethics and morality are not the domain of AI. Humans need to keep a reign on it.
    • New to this forum.  Also looking to tune a 6L80 and trying to work out all the issues in my transmission swap.  I have a 6.2 diesel (1983) and have removed the TH-400 and about to put in a 6L80 with a TCM-2600 interface and don't have a clue what I doing after that.  Did you (Leatherneck/RAV3) get your slip resolved? I too hate to spend that kind of money on a tuner that hopefully I will not need too many times although from what steelerdude15 added about the HP Tuner being great for diagnostics would be a plus.  I am also from WNC but below you in Columbus.  Any helo would be greatly appreciated.
