Removing rear block.
Archaic2021
Is there still a factory rake after removing rear block. I have currently a 2.5" RC level on my truck and wanting to go back to more of a stock height. The kit uses a front leveling kit and a top strut spacer that I believe is only .25" tall, also the rear block. My idea was to remove the rear block completely and then removing the lower front leveling kit only. The truck has a slight rake now. I was thinking they still had a rake even when I removed my rear block before. My idea behind this is to have the .25" spacer on the front and have no rear block to give it a complete level.
Block is about 1-1/4" thick. When first got my truck I pulled the rear block. Didn't like the look at all. Truck didn't have that "lowered" look, just looked kinda wimpy. Within a week, reinstalled the rear block and added a 1" front end lift (1/2" lower spacer). Much improved. Truck now has some rake but looks like a 4x4 without being too high overall. I think removing the rear block and leaving the upper 1/4" spacer might put the front end just slightly higher than the rear.
    tblt44
    tblt44
  • Who's Online   1 Member, 0 Anonymous, 510 Guests (See full list)
