New member in Jax, Fl. First Rado
keaneb23
Hello I just recently bought a 2016 Silverado 1500 Double cab LT.
it is 4x2 :( but I never really used the 4x4 in my Titan.
I also own a 2004 nissan titan 4x4 with 6" rough country lift on 35" toyo mt. Blown rear and front diff led to me to the chevy dealer.
I do not have leather, i plan on getting katzskin.
exterior color is black. I just blacked out the emblems front and back and removed the lettering from the tailgate.
5% tint all the way around plus 30% tint on the windshield with a 5% strip all 3M film.
to come: escort blendmount, shorty antenna, led reverse lights, tag lights and bed lights. I have the 17" wheels i want to get the 18" z71 or the texas or all star im not sure which but those on k02 33-34.5.
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 393 Guests (See full list)
    • 2013 5.3 still to this day calls for the PF48 filter.  Which as a 15psi bypass pressure.     There is a TSB, 17-NA-157 that talks about the PF-63 and PF-64 filters which have a higher bypass rating of 22psi.    TSB HERE - temp.xml   "Beginning in 2012, the oil pumps began to regulate main gallery feedback instead of pump out pressure. This means that the oil pump now does not begin to regulate until pressure is built up to the main gallery. This change reduces the amount of time it takes to provide oil to the engine bearing and lifters during extreme cold start conditions.  Main gallery feedback oil pump control systems are present on the following engine families which use Spin-on oil filters: Small Gas Engine (SGE), Large Gas Engine (LGE), High Feature (HFV6) Gen2 and Small Block Gen5 gasoline engines. These engines with the main gallery feedback oil pump control systems are factory built with an ACDelco® oil filters"   It also calls out what engines use those filters.  The gen 4 small blocks were not on that list (LMG, LC9, L9H, L92, L94, L20, L96).  Gen 5 small blocks use the higher pressure filter.
    • To me it honestly makes zero difference what filter you run. It's not a race engine, just a truck engine that's mostly bumming highways and it just needs a filter that filters oil.   The filter used to be a 7060 and the long version was a 7045. Now it's the newer updated filter that the K2XX trucks and newer run, the 100255 I believe if we are using napa numbers. Any of those filters is going to do the job.   I wouldn't overthink it, to me it makes no difference because those first filter numbers worked for 18+ years before the spec suddenly changed.
