2016 audio help
I have a 2016 Silverado crew cab z71 with factory non bose 8in sceen. I am not new to the car audio world but it has been a while since I have messed with any of it. I will be retaining the factory head unit and splicing into the rear channels of the factory headunit using a audioconrol LC7I, from there I plan on running a rockford fosgate R250x4 to both front and rear door speakers, and a rockford R500x1 to a single 10 under the rear seat. I know the by amplifing the factory head unit people have ran into problems with the factory chimes, I also realize that the front door speakers and dash speakers are all ran off the front channels of the factory head unit, my thoughts are to only replace and amplify the factory door speakers, leaving the dash speakers stock and running of the factory headunit, that way I still will retain my factory chimes and the chimes will not be amplified. Does anyone know how many ohms the factory dash speakers are? I am guessing 8 ohm, if so I see no reason this will not work. I do realize that the output from the dash speakers will be less if that is the case but that does not bother me and they could be replaced for 4ohm at a later time. The only down side I see is my factory fader will not function properly but I can address that in other ways. Does anyone see any other issues with my plan or potential issues. Thank you all.
Sounds like a decent plan to me. Not sure about the ohm rating, though. If you have an ohm meter it shouldn't be hard to check. If you don't, they're not expensive.
I have the Silverado LT and kept the factory stereo when I had my system installed. What fuse did you connect your remote wire to? Mine is currently on the radio fuse and I think it's draining my battery. I had to boost it twice last week and I took out the amp fuse and no issues this whole week.
  • 3 weeks later...
There is a RAP under the dash -- Let me find the paragraph I saved for mine that I used as a remote.....
Here it is: If you look under the driver's side dash between the brake pedal and parking brake, you'll see the fuse/relay box (it's about 6" x 10" and has a smooth black plastic cover, just like on the GMT-900's). Pry the clasps on each side to remove. On my SLT there are three main banks, left to right, with the first being unoccupied (see attached pic). The slots within first bank are labeled 1-20, though only 11 actually have male connectors. I used my tester to determine the following: #'s 7 & 17 are constant 12v power [always on], #'s 10 & 11 are grounds, and #8 is the RAP [retained accessory power] ignition signal wire (again, see attached pic)
https://www.dropbox.com/s/6p1vcs3rfpfd4p4/Sierra%20Wiring%20Diagram.docx?dl=0
That link should be public, when you open the .docx, you should be able to see the photos. Hope that helps!
thanks man
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 442 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
