Guage cluster
My obometer amd tack amd message centre have all stopped working....checked all fuses and still nothing. ...need advice plz
Probably need to get the high voltage supply circuit re-flowed. 03-04 were notorious for this problem. I repair 3-4 a month with the same problems.
Oops just saw that it's a 1999, then you need to get pin 1 of the display cleaned from old solder and re-solder. Or try and find a junkyard one that works.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 1,220 Guests (See full list)
