My Next Toy
DigUout
Hey I need one of those to drive in Southern Maine in the summer... Dam idiots are back... Beach me leave brain at home... :thumbs: As I tell them... GO HOME!
From the e-bay listing:
2. We are lawyers and not vehicular experts. We have been made aware that this vehicle is not likely to be exportable to North America.
Bummer.
Get some white paint. Paint ANTI RICE on both sides. Just drive around town and see what happens! :flag:
:sigh:
Please stop by the West End of Richmond.
    zibzer2
    zibzer2
  • Who's Online   5 Members, 1 Anonymous, 784 Guests (See full list)
