Too Much?
pacodiablo
Can you have too much of a good thing?
24 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
I can't think of a good thing I could have to much of. I have been told I'm a little narrow minded though. I don't usually think of anything but cars and girls. :thumbs: How can you have too much of that when its good? :)
Have too much of a good thing....NEVER. Timmy is my good thing. Thank God for Nic's dad. He takes Nic for 3 weeks and Tim and I have a GOOD TIME!! :)
Too much of a good thing? By the time you have had too much of anything you might not remember it was a good thing in the first place. Then your little boy or girl looks up at you and smiles :thumbs: just because! Paco- just wait till you're married and have kids and you'll remember this post and say man, he was right. Sometimes the good things come along and you can't enjoy them long enough! :)
    zibzer2
    zibzer2
  • Who's Online   3 Members, 1 Anonymous, 799 Guests (See full list)
