The REAL country cage match
Jpshostr
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
General came up with an unfair one, I mean, who can pick Garth Brooks over Charlie?  I had to redo it and offer a few more choices so you'll actually have to think.  Maybe later I'll put up a female country cage match.
By the way, yes, this poll is officially sanctioned by the GMTC Cage Match Association.  Your participation is valuable.
Yep, the Generals attempt was pretty lame.  I voted for Chris LeDoux on this one.  Doubt anyone else will, but you can't find many people like him who sing really country songs anymore.
I must say, I like dang near every one of those guys you put up there.  With exception to a few, whos new songs are starting to sound alot like pop...
Well it was a very hard choice between Gary Allan and Chris LeDoux, so I flipped a coin and went with Gary Allan, they are both my favorites.  They are always playing in my CD player in the truck.  George Strait is also one of my faves, and Kenny is great too.  But I could only vote once so, Gary Allan it is.      :D
I put Kenny Chesney because I love his music and he is from the same neck of the woods I am from! :D  My brother went to school with him at ETSU for a little while! :D
Elwood probably would, if he was around.  He's on spring break right now and probably won't have access to a computer very often.
George Strait (followed closely by B&D)
I take it you aren't too familier with the country music scene?
You hit that nail right on the head.  :D
Although I did hear a Brooks and Dunn song the other day that was pretty catchy.  I couldn't remember the name of it though if my life depended on it.
I went for Chris LeDoux, though he barely made it out over Charlie Daniels, with George Strait not far behind.  Still haven't seen LeDoux or Strait in concert (they don't come up east too often), but I've seen Charlie Daniels twice (he comes up every year).
Heck, what about George Jones, Merle Haggard, Johnny Cash, Conway Twitt, Hank Williams Sr?  ;)  I guess those guys all belong on an old-times country cage match though....
Can't believe that you didn't include Alan Jackson...one of the few real ones left...
Sorry, once I hit enter I knew I'd left one big name off.  Of course it had to be him, and I can't edit the choices. :D
    Gkistler
    Gkistler
  • Who's Online   4 Members, 0 Anonymous, 877 Guests (See full list)
