daylight headlights
Hi, all is there a fuse on the trailblazers that can be disconnected to keep daylight headlights from coming on/ I found the one on my 2000 sierra and pulled it, don't know if there is one on the trailblazers? Thanks
If it's anything like my truck, you can disable them. With the truck running, depress the Dome Override button 3 times, you should hear a "chime". You're DRL's are now off. This also works for the automatic headlights as well.
Only problem is remembering to do it every time you get in the truck :smash:
Yes, that is true. Or, if you have a 2003 model, you turn the headlight switch to the left and it also temporarily disables them until you cycle the key.
