Change center/jump seat
i'm trying to swap my jump seat that does not have the lower storage area to one that does. Getting the seat out is no problem (4 bolts), but disconnecting the USB and 110 are the challenge. Is it easier to:
1) disconnect under the passenger seat (do i have to take that seat out?) or
2) plug into the connections in the seat? How easy is it to pull the seat fittings apart?
I have the wiring for both seats. Thx
i finished this up and figured i'd post in case someone is curious down the road. The passenger seat does not need to be removed. You can reach them with the seat slid all the way back or forward. It's a bit of a hassle to unplug the connections, especially the 110 connector,
I found having the seat back was ultimately the easiest. The connectors have fittings on the top that need to be released and then they can slide apart. I had to use pliers ultimately to get the larger 110 apart as i couldn't get enough of a grip under the seat.
Once they were undone, it's a piece of cake to fit the new ones together and bolt it down. Lovin the extra storage now.
Thanks for the perfectly timed info as I'm about to do the exact same swap!
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 423 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
