04 GMC 5.3l gas exhaust questions
so i got a 04 gm 5.3l 1500 z71 its got 463 front and rear gears superchip in perfomrnace tow and haul mode kn air filter and ftermarket performance heavy duty xfer case with heavy duty knucles and added leafspring in back its got a 6in procom suspension bracket lift and 3in procom body lift. its running california stock cats and 2.5 pipe and has a cali turbo mufler dumped behind cab. i want a deep aggressive souding system i was thinking between the flowmaster super 10 or super 40 or cherrybomb ex muffler 1 in 2 out. i dont know which sounds louder and has more aggrsive low end and rev. also i love the drone and wodneirng with my setup do i want 3in pip all the way back or keep my 2.5 stock pip or what. any suggestions.
    ballencd
    ballencd
  • Who's Online   5 Members, 0 Anonymous, 713 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
