I am looking for the torque specs on everything that has to do with the pitman and adler arms, tie rods, steering box etc. Anybody point me in the right direction I can't seem to find them anywhere?
You haven't tried the most obvious source...a local dealer's parts or service department...
Idler arm to frame bolts - 122 ft.lbs.
Idler arm to center link nut - 92 ft.lbs. This is a one time nut. You need a new nut if its removed for any reason.
Pitman arm to center link nut - 92 ft.lbs. This is a one time nut. You need a new nut if its removed for any reason.
Pitman arm to gearbox nut - 273 ft.lbs.
Steering gearbox to frame bolts - 203 ft.lbs.
    hotfish
    hotfish
  • Who's Online   6 Members, 0 Anonymous, 839 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
