Broken Mirror GOOO
I hit and cracked the lft outside rear view mirror this morning, by the time I got to work a thick green liquid had welled up in the mirror. It leaked out, damaging the clearcoat on the left side of my Yukon XL from the A pillar back, permanent stains from the windows to the rocker panels. What the heck is this stuff. My truck has 600 miles on it .Any ideas what to do? LILGUY
Sounds like electrochromic goo.
Maybe you can claim the mirror broke on its own and claim warranty service, but it sounds like if the clearcoat is damaged, it'll need repainted.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,025 Guests (See full list)
