Armo325's 4WD 2017 Silverado Double Cab LT Z71
Armo325
A couple updates.  I uploaded a better clip of the tail light LED bulbs in action:
I also opted to swap out the "dot" style marker lights in the tow mirrors for some Boost Auto "strip" style lights.  They went in this past weekend:
I have a few more items on the list in the coming months but first I need to get a little cash together.
  • 4 months later...
I finally managed to pull the trigger on new gears and a Black Bear Performance tune.  Like countless threads on here about re-gearing lifted trucks, my only regret was waiting this long to do it.  I ended up going with a 4.10 ratio.  I love the new setup.  I definitely feel like the truck has regained what was lost with the bigger tires.  While I was at it with the gears, I also threw a Fabtech add-a-leaf in the rear springs to get a little of the rear height back.  The Fabtech lift almost perfectly levels the truck but I prefer the rear a bit higher as it comes from the factory.  Here's the new, all-inclusive list of mods:
Fabtech 6" Gen II suspension lift
Fabtech rear add-a-leaf spring
Fuel Krank 20x10 (-24mm offset) wheels
Maxxis Bighorn 325/60/R20 tires
4.10 differential gears (AAM rear, Yukon front)
Black Bear Performance custom tune
McNally 16oz. dual-valve catch can
K&N Blackhawk intake
New cat-back exhaust with Flowmaster Super 44 muffler
Retrofitted GM camper mirrors (swapped door harnesses for light functionality)
Replaced mirror lights with smoked lens marker lights and Boost Auto parts relay for turn signals
Rockford-Fosgate P3SD4-10 subwoofer in custom enclosure
Replaced tail lights with LED bulbs and resisters
Replaced headlamp assemblies with LTZ OEM assemblies
Replaced door speakers and dash tweeters
Painted calipers
Frame tube plugs
Here's a few recent photos.  I apologize for not cleaning the truck beforehand.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   1 Member, 0 Anonymous, 545 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
