Possible electric problem on 04 1500 5.3L?
So I’m not sure what the deal is and I don’t want to waste money, so I wanted to see if anyone had any insight for this or had this problem in the past.
Recently, my passenger side Hi and Low beams went out. Drivers side hi and lows still worked. Checked them manually by flashing them, but nothing. So I tried swapping the driver and passenger lights. When the passenger lights were put into the drivers side, they still didn’t turn on. When I put the drivers side into the passenger side, they didn’t work either.
So I then switched them back to the side they were originally on and now neither side works.
Thought maybe it it was the relay, so I’m going to try that. Neither bulb was burnt out, all fuses are still good, and I checked the line to see if an animal but through it, but it’s fully intact all the way to the fuse box.
Doea anyone have an idea on what it might be?
you need a dmm to ohm test them.  then measure for voltage at the bulb sockets
My neighbor has one, I’ll check it when I get a chance.
Hoping its not electrical but rather just a new wire harness.
On 12/13/2017 at 7:39 AM, carnau said:
What did the end of the connector look like?
I haven’t fully looked at it yet. Did those preliminary checks pretty late and had work the next morning. Been working since on the  damn shift work the army has me on.
    appletrav
    appletrav
  • Who's Online   0 Members, 0 Anonymous, 279 Guests (See full list)
