2015 Sierra new owner
Herms21
Hello all,
brand new new to the forum just introducing myself. Traded my 2012 Silverado 2500 yesterday for the new pickup. Just a couple of things i’m looking for opinions on;
-preferred floor mats/liners for these pickups. I live in ND so some that contain slop is a must for myself.
-is there a preferred leveling kit by manufacturer and what is the desired amount to level the pickup so that front isn’t higher than the rear
-this goes with the last question as to what size tires with what amount of leveling i can comfortably run
-also preferred tires you all run. i’m partial to the BFG KO2s but considering both Goodyear duratracs and Cooper STT pros
forgot to add with the level and tires that i will run the stock 20” wheels
If there is anything else you guys would like me to know just throw it out there. Will appreciate any feedback and comments.
thanks
    rayredbone
    rayredbone
  • Who's Online   1 Member, 0 Anonymous, 480 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
