He's a republican from birth
R Dogg 56
That woman embodies the stupidity of the voting public in NY! Well, that and all that is evil. She's a Man BABY!!! :confused::puke:
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 1,401 Guests (See full list)
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
