BETTER MAKE SURE
greyghost03
I should put that on my yoda. :thumbs:
I tryed to convince my friend to put a big bowtie on the back window of his '91 Ranger. :lol::lol:
I tried to convince my friend to put a big bowtie on the back window of his '91 Ranger.  :lol:  :P
Paco wouldn't do that. :thumbs: We would pick on him too much. :lol:
    contrabombarde
    contrabombarde
  • Who's Online   1 Member, 0 Anonymous, 1,404 Guests (See full list)
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
