Skid plate
Hello there lady's and gents....
I'm looking for a bumper filler and the skid plate for my 2016 z71 crew cab if any one has a take off that is just collecting dust in the gararde let me know, i just hate the way it looks with out it.
Thanks in advance.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 1 Anonymous, 1,183 Guests (See full list)
