Chevy security system light? Any ideas?
So I decided to install a remote starter on my '03 Suburban.
If you decide to do this, there are two ignition wires that need power, not just one! Mess that up and you can damage the trans and get a check engine light.
In order to make it work, I had to bypass the resistor in the ignition tumbler. Otherwise, the car would start and then immediately shut off. Basically, you cut the wires that go to the tumbler, connect them with a resistor, and then do a "re-learn" for the security system.
Anywho, after doing this, the remote start works perfectly, however - the security light is always on. The standard way to turn the light off is to disconnect the battery for a bit, but it didn't work. Any thoughts on this matter?
sounds about right but the light shouldn't be on if you did it right. integration modules for that year/make are cheap now, with the addition of adding keyless entry if you have power locks.
orange in color wire shielding, two white smaller wires inside, cut one of those wires, find resistance by using multimeter to key switch side of cut wire to 2nd wire that was not cut(and be within 20%), then connect resistor to the BCM side of cut wire, then connect to 2nd wire that was not cut. the other end of cut wire that goes to the key switch is taped off and not used.
    appletrav
    appletrav
  • Who's Online   1 Member, 0 Anonymous, 316 Guests (See full list)
