Anyone take online courses?
chevy4x4trucks
I was looking at:
http://www.classesusa.com/categor....4673924
And was interested in a bunch of the courses there for: Photoshop, HTML, A+, C++, Networking, Java, Perl, Macromedia Software, and a few more (yeah I know that's a lot of them).
Anyone ever take online courses like this?  Are they really hard?  Do they help you out?
I want to expand my knowledge and stray from doing drafting work and get more into my hobby which is messing w/ computers (networking thru webmaster).  I figure I'd rather do a job that I really enjoy doing and is a bit more challenging.
I'm going to scope out the local colleges and perhaps quit work, go back to school full time and find a part time job to keep up w/ the truck payments for a year while I take some more schooling.
Now to just check on that part time job I was looking at :D
Cool, this is about the only way to take all the classes that I want.  The local colleges have bogus schedules for most classes, which is the main reason that I haven't finished my associates degree in mechanical design.  The classes that I have left are at weird times.  One of them is two credits, 4 hours a week and the class times were different each day (and by each day, it was split up into 4 class periods, each on a different day) and one of them had an hour break in between.  Way too much time to waste, especially w/ a 1/2 hour drive to the campus and paying for parking each time.  Not only that, but it would be the only class I could take because it would interfere w/ every other class on my schedule.
Larry, have you taken any classes online yet?  There's a few at the local campuses that I'm going to take and a few other ones that are being taught in the area as well, but the bulk will be online courses.
Any recommendations other than the ones I listed?
My company currently bought access for all of its employees on this website Online Training.  I've been through the A+ and now I'm working on all the networking stuff.  Seems pretty good...not sure how much it costs though.
Eric
my english 101 class is online. god it sucks. for computer based classes, i strongly suggest going to a class for those. specially network ones dealing with routers and switches. you'll never get as much out of the onlines running stuff like router esim (cisco program). the A+ ones you shouldnt even need a class for, its extremely easy test.
I think I'm going to take some of the courses at the local tech school.  Me thinks I should get the A+ Certification and MCSE certified.  In addition to that I'm going to take some classes on JAVA script as well as a few other web related stuff.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,253 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
