Bowtie Replacement
Hi All,
Had a nice qrtr sized rock jump up and hit my bowtie emblem and put a nice spiderweb on the plastic housing. Im lucky i guess cause if it hit my bumper or hood it could have done some serious damage. I do have the 3M clear tape on my painted front end to protect from small rocks but this was serious..... I know the bowtie is attached by two clips, Im wondering what the best way to pull this sucker out is. Does the Grill need to come off? If I pop the plastic cover off above the grill is there enough room to sneak a hand in and release the clips? Any recommendations on the best place to pick one up is? The truck is an 03 Z71 Tahoe. Ive read the threads on this and it doesnt sound difficult just looking for some futher clarification. Thanks for your help!
Hi All,
That's how I got to mine! Took the cover off the top of the grill shell and radiator and there was plenty of room to get to the nuts that screw onto the posts on the backside of the bowtie.
I ordered my extra bowtie that I had painted from GM Parts Direct and I think it was $20 or so.
:smash:
Is there any trick to getting those plastic locking bolts off the top grill cover without busting them? Can you pick up new ones from Gm parts or a delaer? They dont look like they will be easy to get off???
Mine came off pretty easy! I just used the blunt side of the blade on my pocket knife to pry up the center part a little to get my finger under it. You could prob use a butter knife or a flat blade screwdriver would prob work even better. After pulling the center piece out the remaining piece can be pulled out by hand.
They are actually pretty tough. I've pulled them out and put them back in several times without damaging them. :smash:
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
