i need you guys to help me out....
pacodiablo
if you have a CarFax account and are willing to do 1 or 2 vehicle checks for me please read on...
i am very close to finding 2 of my favorite trucks from my childhood...an 85 cherokee and an 86 ranger.  the jeep was last traded in at a nissan dealer and i have no idea where it is now...the ranger was auctioned off, and same story as the jeep.  the truck i really want to find is the ranger.  if i find it, i will get it back.  anyway, if you are willing to run just one car check do the ranger, if you can do 2 for me, please do the jeep and ranger.  enter zip code 27514 (most likely to work)
here is info on the vehicles...
1986 Ranger SuperCab 2wd
base model
2.3L 4 cyl, manual transmission
gray exterior
red vynil interior
VIN: 1FTCR14A5GPA61048
1985 Jeep (AMC) Cherokee 4wd
base model
2.5L 4cyl, manual
blue exterior and vynil interior
- OPTIONS: Ice blue clearcoat paint, P205/75R15 radial tires, 3.73 gears, AC, power steering and a few other odds and ends
VIN: 1JCUX7810FT053208
also, if it helps any, shortly after it's purchase the jeep had an AM/FM mono radio installed by the dealer
and... the jeep was sold by morgan dodge/jeep (and previously AMC/Renault/Dodge/Jeep)...the Ranger was sold to us by Ray Motors (i think thats the name?), they had it transferred from another dealer.  both dealers are in NC
any help in finding the whereabouts of these vehicles is greatly appreciated!  thanks in advance!
I tried to do it earlier, but I hit a road block when I ran into the $$$$.
Sorry I couldn't help paco,but I can say this, the Ranger came up with 17 record reports. If that helps any.
    RangerRick17
    RangerRick17
  • Who's Online   5 Members, 1 Anonymous, 600 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
