Here's a strange one (PC)
SnakeEyeSS
I'm not asking for help, I already solved the problem, but it's so strange I thought I would share.
I recently updated my BIOS and and added a new NVMe drive, and went ahead and reinstalled windows. Then, suddenly, after several days of flawless operation, it won't post at all.
So I cleared CMOS. Then I was trying to remember the bizzare handshake my rig needs to post after CMOS clear. There is something that doesn't agree with something else and you have to do power, clearing, rebooting, rebooting into BIOS blindly because it won't send a video signal, then rebooting again. I just stumbled on the procedure when I replaced have the system but never wrote it down, and wasn't too concerned because it works so well once it's done. (That's what this post is about, finally figures it out). After the latest hardware change I tried Fast Boot again, (saves like 2 seconds) so nce it used to not work, likely because the VBOIS/1070 don't agree with the Fast Boot process (that's what the warning is if it doesn't work). And it suddenly worked, which seems odd since I hadn't done anything with the 1070, so I figured they fixed a flaw in the BIOS. So for a few days it worked great, until today.
I would power off, clear CMOS, power on, it about 30 different combinations, and when it worked it took over a minute to START to post. Something was obviously wrong so I started playing around with fast boot again. It took a while, but finally realized, after trying everything that made sense and started doing stuff that didn't, that upon initial boot, after CMOS clear or a fast boot issue,  the Video Card won't initialize with a display port cable plugged in.
What. The. FLYINGDUNKINDONUT.
I did the whole process again to confirm, as soon as I unplugged the cable from the card the system will boot.
    • when it's greyed out that is it's way of telling you that it's downloading the patch in the background. Eventually it will be fully downloaded and then it will prompt you at ignition shut down to run the update. I highly recommend doing the update once you get home and can run it a few times. I've had several issues with updates not going the first time around and I had to retry the update multiple times in my driveway before it was successful.   Some updates are huge and take awhile to download. You can help it by connecting to your home WiFi and keep the truck on service mode for the ignition and keep it alive for awhile on a battery charger too. There are specs it needs to be in for updating such as a full enough battery charge, no running ignition, etc.
    • I am not techy at all but wondered if you have the truck running but sitting still in park as some functions gray out as soon as the truck is moving. I believe in the settings for updates you can choose for it NOT to update and I wonder by chance if maybe that was chosen before and now it won't allow you to chose to press update, I think that is back in the settings menu where it has all the items one wants on or off etc. Also I assume you have a wifi connection and checked that it has some signal strength, not that it would have anything to do with the grayed out updates choice in that case. What I am thinking out loud of here may be be of no value but thought I would suggest it, sometimes it can be the simplest thing that resolves an issue.
