4L60E Transmission
I drive a 03 Chevy Silverado LT 1500, the transmission went out n the trans I took out of my truck is 4L60E- 2KCD. My question is will a 4L60E -9TAD fit back in my truck if not what can I change for it to fit if anything?
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
