Mirror change, 2016 Sierra 1500 SLE.
New at this and trying to contact Phil Gamboa, sorry if this is the wrong way.. I have a 2016 Sierra SLE with the DL8 mirrors, power adjust and heating. I want to change them out for aftermarket products from Trails End or A1 for towing. If I understand you instruction correctly, I can add turn signals and clearance lighting by some additional wiring for those products.
Contact him at @pgamboa you can click on his name and it will take you to his profile.
He's reached out to me :)  Thanks!
    bellssn690
    bellssn690
  • Who's Online   0 Members, 0 Anonymous, 815 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
