HELP Brake light
2007 Silverado newer body style.  My 3rd brake light bulbs werent working but the two white cargo lights were.  All 4 bulbs are the same so I swapped the brake light bulbs with the cargo light bulbs.  That didn't fix the problem, all 4 bulbs light in the cargo light sockets but none in the brake light sockets.  So I figured it was the harness or connector that was bad.  I ordered a aftermarket replacement that is a sealed off led version.  It's supposed to function like the OEM version.  The middle red lights aren't working still but the white ones do.  Must be wiring from the connector into the truck somewhere.  Need it fixed for expired inspection ?
    hotfish
    hotfish
  • Who's Online   6 Members, 0 Anonymous, 716 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
