Weird Sound????
When i accelerate im getting a loud squeaking noise from the left front.. its a loud squeek and goes away as i accelerate.. it is really loud when i first take off.. any ideas???
Doesn't the disc brake do that when the pad is wearing thin? There is this piece of metal that will scratch the disc telling you it needs to be replaced. I took a screwdriver and pryed it up until I can get them replaced.
doesnt do it when i apply brakes.. plus i put new pads and got the rotors turned like 3 months ago... im confused.. im thinking maybe u joints or something
Wheel bearings maybe?
Or the alternator...Those things can make all manner of noises loooong before going bad, and sometimes it's a b!tch to locate where it's coming from.
Or it could be an almost dead cat. :smash:
does it do it at idle???
if so check you belt tensioner pulley...mine didnt do it at idle but from 1200-2500 rpm
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
