2000 6.0l to newer 4l65e
JeepinMike95
Hello, I’m new to the LS world, but I have a 6.0l from a 2000 Chevy, and I just purchased a 4l65e from a 2003 Chevy Silverado SS which had a 6.0l. Yes I know the 4l80e seems to be the better transmission but I’m putting this driveline in a Jeep and the 80 maybe pushing it for room! Anyways I’m just seeing if the 2000 6.0 will bolt right up to the 03 4l65eor will I have to change some parts ?? Thank you
    rayredbone
    rayredbone
  • Who's Online   1 Member, 0 Anonymous, 495 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
