Can Someone Look Up This VIN
Truckman031
Clean according to Carfax
"Year/Make/Model: 2000 CHEVROLET S10
Body Style: CLUB CAB PICKUP
Engine: 4.3L V6 CPI OHV 12V
Fuel: GASOLINE
Driveline: 4 WHEEL DRIVE
Manufactured in: UNITED STATES
Safety Equipment: 4 wheel ABS, Running Lights, Dual air bags front/active (manual) belts with passenger side deactivation switch
Standard Equipment: Power Windows Optional, Power Steering, Air Conditioning Optional, AM / FM, Power Brakes, Tilt Wheel Optional "
    contrabombarde
    contrabombarde
  • Who's Online   1 Member, 0 Anonymous, 674 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
    • No, we trade them like pokeman cards.
