Jeep Question
Elwood
My boss just bought a '97 Wrangler to fix up. He has a friend who is willing to give him the axles off of his '97 Grand Cherokee because the ones on the Wrangler are completely shot. Will these fit without modification? If it does require modification, how much does it require?
they should swap out ok. i believe both are going to be dana 30's. the
only thing i'd double check is the gearing to make sure there the
same if thats a concern. also check @ www.jeepsunlimited.com
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 1,133 Guests (See full list)
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
