Non opening valve after start up 5.3 amf
I have a 2008 amf 5.3
recently I had a lifter stuck on cylinder 4.
i replaced that lifter and the valley pan that has the volm controls on it with success.
i then had a lifter slowly start to fail on 7.
i replaced it with all other amf lifters completing all amf lifters are now new.
at start up I heard a single click.
and dash signal reads engine misfire and constantly blinks with the traction control off signal.
i found the valve to be stuck closed. However easily unstuck with a light tap.
if I rotate the engine with spark wires removed and injectors unplugged, it works normally. I did take the head off again and replaced the intake and exhaust valve which looked ok.
i also removed and reseated all valves and replaced all valve seals.
same thing . It made the same single click at start up and still misfires on seven.
is it an oil delivery problem to the lifter?
and also it smokes a lot now
I have seen new AFM Lifter bad out of the box. Possible a new lifter is bad. Also have heard a single click on start up and it was the A/C compressor turning on.
    appletrav
    appletrav
  • Who's Online   4 Members, 0 Anonymous, 485 Guests (See full list)
