Keyless Entry problem
So I have a 2006 GMC Sierra 1500. Just recently when you open the door the radio will stay on when you close it. You have to open the door again to shut the radio off. Around the same time
that this started happening the key fob will work for about 5 mins. After that time frame nothing will work. You have to manually open the driver door to get in the truck. After that the fob will work for about 5 mins then back to square one. Any suggestions on where to start looking?
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,155 Guests (See full list)
