2015 Sierra driver side window not working
Ls1perf
I got an 2015 Denali Sierra and I’ve got a problem with the driver side window not going up or down. All the windows works fine on the master switch except the driver side window. With that being said does anybody know what could be wrong. Is the master switch bad or is the motor bad? Or what fuses to check.
Amazing post, I have a 2015 Denali as well surprising or not surprising I guess my driver's window stopped working properly yesterday I can lower the window and put it up but then when it's in the up position it decides to go back down at any level it wants, I can at least get it up to a point and then hit the switch again and it will stop where it needs to however it doesn't do it automatically anymore. If I hear of any resolutions to your problems I will share it with you as I am looking at other sites as well for information. Good luck and if you figure something out let us know.
I’ve seen people also have the same problem as you when looking up solutions for my. Check this link out it might help you...
    timcpeters
    timcpeters
  • Who's Online   2 Members, 0 Anonymous, 1,199 Guests (See full list)
