Looking For Heater hose connection for 88 Scottsdale
I have a 1988 chevy C2500 I had coolant coming from the passenger foot well and upon investigation found that the hose from the firewall to the heater core was cracked and broken. Im trying to find the replacement part number for this hose. Its about 8in long and forms a slight S shape with a female connection to the heater core and a male connection to the hose on the firewall.
    ballencd
    ballencd
  • Who's Online   5 Members, 0 Anonymous, 713 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
