Engine bogs and dies
I have a 2005 Jimmy with a 4.3l vortec
I have had a excost leak and just got it fix
Before i had it fix my truck ran like crap
Would sputter, die and when under load the engine would want to die.
I have changed
The wires
Plugs
Distributer
Fuel filter
What happens is that it eaither will start and die soon as i hit the acclerater or it wont start at all
I get a yellow coloured spark when checking for spark
As well when i hold the thtoddle body open as i get a helper to turn it over i get shocked.
I have no idea what is wrong and if anyone can help thank you
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,123 Guests (See full list)
