Interior lights
Brad1246
My dome light, map lights and the visor lights quit working this morning. Can’t find the fuse that works them.
Does your left taillight not work as well? I had a similar issue...
Sent from my Pixel 2 XL using Tapatalk
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 765 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
