anyone into aircooled VW's?
EXJAY
if anyone lives or is willing to make a trip, were tring to get a decent turnout for a meet and to check out some vw's and do a cruise on the blvd. its going to be held on the 18th at 2pm at the hard rock cafe parking lot at broadway at the beach. its located at the corner of 29th ave n and hwy 17 bypass n. hope to see ya. :rolleyes:
    contrabombarde
    contrabombarde
  • Who's Online   1 Member, 0 Anonymous, 885 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
    • No, we trade them like pokeman cards.
