Jump seat set back mounting
Kim Kanis
I am looking to remount the double cab center jump seat further back to get more room.  Has anyone done that to their truck?  Thanks!
  • 4 weeks later...
Kim Kanis, did you ever get your jump seat moved back.  I am thinking about doing it on my crew cab and was wondering if I would have to drill holes or if there is an adjustment on the bottom of the seat to move it back.
I have the silverado jump seat in the burb for a second row jump seat. There is no adjustment, just bolt holes, so you either need to drill new holes with threads, or add a sliding seat bracket to existing holes...
Sent from my SM-G975U using Tapatalk
Thanks for the advice,  I chose to cut down the backrest with the cup holder removed.  I removed the seat cushion and left the open compartment with the cup holders remounted into the dash side of the compartment.  Now the cup holders are closer to the floor and the small bins are still attached to the front edge of the armrest/top compartment.  Still have full electronic connections too.  Looks good and more legroom to boot!
    rayredbone
    rayredbone
  • Who's Online   1 Member, 0 Anonymous, 488 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
