4x4x
Ok my 4x4 stopped working when I was trying to put it in 4 wheel drive ,it's a 2007 new model with the dial. Replace the tccm and the actuator but not the switch witch says it is in 4 wheel drive but is not. Any ideas where to go from here.
I have the problem where it won’t switch out of 4x. It finally does a few days to a week later
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 950 Guests (See full list)
