1999 Silverado not entering programming mide for remote entry
Greg1
My remote fob quit working. I replaced the battery with no luck. Bought new remote, but cannot get into programming mode to use new remote. I followed the programming instructions, but the truck is not responding. Could this be a problem with the receiver in the dash? I read that there is fuse to pull to reset the receiver. Any thoughts/ suggestions?
