Replacement injectors
I have replaced my injectors (lb7) twice. I’ve only gotten about 65k miles from each set. These are reman, one set stock and the 2nd set +50 hp. It is smoking at idle (blue smoke) and a lot more smoke towing.
My question is now I see new Bosch (not reman) injectors that I’m thinking about going with this time.
Has anyone installed the “new” injectors yet? I’m hoping to get feedback before going through the replacement process again!
Thanks
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 950 Guests (See full list)
