Not much response
2000 Sil. 5.3, 2 wd. 55K. I am having a problem with no mid range throttle response. Its as if its struggling from about 40 to 60 mph. If I floor it then I get great response. But if I am moving along in traffic and want to ease up its like it just doesn't have the same response as from take off. Any ideas??
for some reason the shift points are different than on the 99 mods
my 99 just had to barely push the pedal at 40 and the convertor would
unlock and away we go
but my 00 sierra just seems to take more and more pedal bfore it will down
shift
by the way what kind of mileage do you get
wish i had my 99 driveline in my 00 sierra
got 19 mpg out of my 99
15.7 tops out of my 00
Definatly the torque converter locking up. Flooring it unlocks the clutch. Really no way to cure it other than custom programming. Have you thought of a Wester's PCM? Wester's can boost your low and midrange torque quite a bit, and raise the clutch lock-up speed, and make the clutch release with less throttle pressure. It makes the truck feel like you put a big block in it!
Butch 02 Sierra Denali
I'm with shaners. Hopefully the previous owner recorded maintenence in the owners manual. If not, assume it's never been done. You may be getting close to a transmission filter change or at least a flush.
:withstupid:
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,163 Guests (See full list)
