Rust Protection
Hello,
This will be more directed to my fellow Canadians but could be interesting to all. In Quebec and Ontario we have a dealer for rust protection called "Metropolitan". I just had my 95 K1500Zer done yesterday. Looks like they did a fairly decent job for only $85.00. I was contemplating going to Rust Check like last year but there cost sent me elsewhere. I do not see much difference in work to be honest. Every year I pull aside the front carpets and give a good spray in there with an aerosol but thats it.
If anyone else has had any experiences with rust sprays good or bad send them in, I would be curious.
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 716 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
