2013 Chevrolet Silverado 1500, 5.3 starting issue
Good evening
Please bare with me...
I have a 2013 Chevy Silverado with roughly 80k miles.  I had been getting a bunch of codes with a CEL: MAF, Rich and Lean codes, with an intermittent AFM code (truck not able to switch to 4 cyl).  I took it to the dealer -  they cleaned the MAF/throttle body, replaced a shot oxygen sensor (downstream), did some preventative maintenance and inspected it for about $1k.  Initial driveability issues were better and didnt have any problems.  Took a short trip a week later and ended up with a Misfire on Cyl 1.  I did the easy thing and pulled the spark plug.  The insulator was cracked and shorting out.   I replaced all spark plugs and truck cleared the code and it was driving well.  A week later I began having the odor of gasoline in the cab of my truck.  I called the dealer, when i got it in they diagnosed it with a rusted/corroded fuel pump and a high pressure line.  They got around to fixing it a week later.  I got the call today to come get the truck and took it out, (another $850).  At first it was driving well, but when I got the truck home, it sat in the driveway.  I went to move it after shoveling the snow, where I usually park it and it would barely start.  It stumbled and sounded like it was misfiring across all the cylinders, then turned over and idled with no problems.  I turned the truck off and back on, no issues.  I let it sit for about an hour and started it, no issues.  So it appears it is a cold start issue?  I called the dealer back to tell them it wasn't fixed and what was going on.  New appt on Thursday of this week, but until then, any suggestions/thoughts on what is wrong?
Any help is appreciated
    ballencd
    ballencd
  • Who's Online   4 Members, 1 Anonymous, 595 Guests (See full list)
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
    • I'm putting in an A-pillar pod/gauges, and I'm asking if anybody can identify a (preferably) fuse for a switched power and illumination circuit on the driver's side interior fuse panel. Offhand, everything I checked with a test light was constant-hot, and I'd much rather uses a piggyback fuse. I can certainly find a wire, but I'd rather not half-tap.   Thanks in advance for any help.
