PCM pin #14 BLK/red ...HELP!!!!
I have an 06 Silverado radiator fans where stuck on 100% I pulled 14 and fans are running perfect now.... Any ideas why 14 is causing fans to run at 100%
Oh the AC is off, pin 14 green side, has 5v as soon as I turn the key forward ac off. I tried to unplug both ac pressure sensor, and in plugged the control switches in the cab
    hotfish
    hotfish
  • Who's Online   5 Members, 0 Anonymous, 815 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
