Hi guys, yesterday I had to replace both batteries in my 2015 Sierra 2500hd diesel. It was straight forward and easy, but after replacement  my Amp Research power running boards stopped functioning completely. I double checked the fuse was good, I double checked the ground was good. But still no operation.
Does anyone have experience with this?
Perhaps needing a reprogram?
Thanks to anyone with info!
Having the same issue in my girlfriends truck. 2017 Silverado rocky ridge. Battery died, so we had it replaced and now the amp research steps will not work. Ever find out what it was?
blown fuse.  replace the fuse.  its clear color fuse in the red compartment.  you should be able to see it when you pop the hood towards the battery on passenger side.
That happened to mine as well.  The fuse wasnt blown.  I just took the fuse out and put it back in and it fixed the problem.
  • 9 months later...
https://youtu.be/RRkhi9RoRe8
Here you can find how to fix the steps by removing the fuse. In the comments there’s one posted by Sam C. :
“Everyone driving a GMC with this problem. I did the fuse thing, didn't work. Look through the internet. No
solution. What worked for me was to unplug the module beneath the steering wheel. I then opened all the doors on the truck. Then I turned it power on.
Didn't have to turn the engine over. Then plugged the module back in. Then closed all of the doors. And it worked.” Hope either solutions solves it for y’all.
  • 5 months later...
I had this same problem with my 2013 Silverado after disconnecting the battery for another issue. I pulled the fuse, cycled ignition on then off. Replaced fuse, and steps started working again.
I took the fuse out and put it back in. It's the red fuseholder that goes to the positive + post. That's all it took
    ChristopherDobson
    ChristopherDobson
  • Who's Online   2 Members, 0 Anonymous, 1,164 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
