Fog Lights Flickering??
dKelly22
Hello! I own a 2017 Silverado LT. My foglights recently have started periodically flickering or almost strobing. Had it to the dealer three times and they've replaced BCM and some grounding. After replacing BCM it was fixed for a week and now doing it again. The only thing that has changed with my truck is i bought a new Hypertech speedometer calibrator for my smaller wheels during winter. Would this somehow be causing this? Thank you for any help!
    contrabombarde
    contrabombarde
  • Who's Online   1 Member, 0 Anonymous, 885 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
    • No, we trade them like pokeman cards.
