ANOTHER NEWBIE
EASTCOASTER
NEW TO THIS SITE, I HAVE A 2002 GMC SHORT BOX STANDARD CAB Z71
I JUST DID NEW CAT BACK FROM GIBSON, DUAL SPORT.
LOOKING TO GET NEW INTAKE. AEM, VOLANT, SOMETHING ALONG THOSE LINES.
THEN RE-CHIP.
I LIKE THE GIBBSON JUST FINE..NOT TOO LOUD, BUT I KNEW THAT
THE GUY NEXT DOOR HAS THE SAME SET UP
JUST MELLOW. IT'S MY WORK TRUCK, AND I SPEND A LOT OF TIME IN IT.
DIDN'T WANT IT TOO LOUD.
PUT NEW OUTLAW II WHEELS AND NEW PRO COMP AT'S ON YESTERDAY.
GOT THE OUTLAWS BECAUSE THEY ARE WHAT'S ON MY MOTORCYCLE
TRAILER. :confused:
I just love to hear from the newbies but I could read your post a little easier if you turned of the Cap Lock. It is just a thing with me My problem not yours.
Now for the truck. It sure is fun bolting on new performance parts isn't it.
Enjoy.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,163 Guests (See full list)
